Invert Digital Array, or Invert Boolean Array
Is there an elegant way to invert a digital array so that every 0 becomes 1, and every 1 becomes 0? Or is it possilbe to invert a Boolean array so that every True becomes False, and every False becomes True?
Ron
(I'm currently using a "Select" too and placing a "F" on the top, and a "T" on the bottom.
(6,200 Views)
Accepted by topic author rsi77
On the boolean pallete you will find the not function. Feed the array through it.
Now Using LabVIEW 2019SP1 and TestStand 2019
(6,195 Views)
Thank you!
that's exactly what I was looking for.
(6,192 Views)
rsi77,
You can Xor the array with TRUE:
Rgs,
Lucither
"Everything should be made as simple as possible but no simpler"
(6,190 Views)
OK, that's prettry clever. I can use that as well.
(6,176 Views)
And if it is an array of 0's and 1's,  subtract the array from 1.
(6,167 Views)
