Invoke Block COM method mismatch
I have a COM server with properties and methods. The Properties are all
correctly accessible. The Methods appear to be mismatched. For example:
id1 Prop1
id2 Prop2
id5 Prop5
id7 Stop
Calling Stop, executes Go.
Has anyone ever experienced this problem. The COM server works properly from
VB6, .NET, mathcad, ...
Thanks, Jeff
(2,781 Views)
Jeff,
    This seems a little bit strange that they are mismatched only in LV. Could you post your LV code and let use know which COM object you are using along with a simple example of the VB code that works correctly. I will have to look into it more once I can reproduce the issue on my end. That way if it is a bug or something wrong with the Object Server I can see what we can do for a work around. Thanks
Tyler H.
(2,770 Views)
