Invoke Control Image for Class Private Data on DVRs, Maps, Sets do not contain full image data
Is anyone able to confirm this bug outside of LV 2023 Q3 64bit?
I'm documenting our Class and its Class Private data elements and I'm having trouble obtaining a full set of image data when calling the invoke 'Get Image', but only in unique scenarios. It doesn't obtain for these type of control hierarchies:
- Class Private Data Cluster (OK)
     - DVR (OK)
          - Cluster, Map, Set (only renders partially)
               - Cluster 1st element (OK) say its a DVR
                    - Map (only renders partially)
Using 8 or 24 for Image Depth has no effect. It outputs a transparent or partially transparent image (where the size is correct, but the image data is not). Please refer to the media attached showing the image data when exporting thru the Report Gen with MS Word. The standard Cluster within the DVR draws fine if I call it from the TypeDef itself, it appears only within DVRs the first level behaves wonky (not drawing properly or getting description and tip strips on occasion). The image data doesn't show any mask or colors array content so it's not that either.
Cluster size is good, but no image data (BG Transparent is Gray). Map is partially obtained.
Cluster within a DVR shows no image data, but the actual Typedef Cluster renders fine if I load it from the Typdef itself.
I'm obtaining the reference recursively with the DataValueRefNum.Element and recursively reading the generic Control properties.
This is also an issue for other nested types like 'TypedRefNum' elements (Queues, Notifiers...).
Kevin Shirey | CLA | Champion | Senior Project Engineer II | DMC
Message 1 of 1
(1,333 Views)
