Invoke Method does not have FIFO Start in LV 2015
Hello
I am trying to get data logged to my hard disk using cRIO 9075 and I am applying the following Tutorial:
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000x0UdCAI&l=en-US
 In step 21 and step 22 in this tutorial it asks for using Invoke method and selecting FIFO start
There is no such selection
Any help?
(3,487 Views)
Can you attach the project/VI which you have made so far? If you want to use that method, you need the invoke method to be using an FPGA reference that uses a DMA FIFO.
(3,480 Views)
Here
Those are the files
(3,476 Views)
Accepted by topic author Ihab
For your project, it's going to be Data > Start. The tutorial selected FIFO > Start because they wanted to start the DMA FIFO named FIFO. Your DMA FIFO is named Data so that's what you are going to start.
(3,468 Views)
