Invoke node error "Full Memory"
Hello LabVIEW enthusiasts,
I'm woking on a data acquisition system to acquire data from a milling process. Inside LabVIEW I'm using some invoke nodes. Unfortunately they give the error "Memory full" after acquiring a specific amount of samples. This amount of samples until the error occures depends on the number of invoke nodes I'm using (depends on the number of variables I want to acquire).
Those invoke nodes are located in a while loop. Every execution of the loop reads one variable from the machine. I'm closing the reference of the invoke nodes after acquiring the number of samples I need, but the error occures fist.
Is there a way to reset the memory of an invoke node inside my loop?
Please let me know if you need more information.
Unfortunately I can't share the VI with you.
(4,414 Views)
Hi ZMK,
the question is: why do you need Invoke nodes at all?
Please attach your VI for more detailed suggestions!
(4,386 Views)
-How you are acquiring data?
-what method you are using in invoke node to get data?
-are you building these data by indexing to while loop?
-are there any indicators/graphs/charts present in your vi?
-how do you know memory is full because of invoke node ?
-can you profile and tell which is taking memory by using : http://digital.ni.com/public.nsf/allkb/9515BF080191A32086256D670069AB68
uday
(4,378 Views)
Well, we really don't know what you are doing (but it seems strange to many of us).  Don't "share the VI" with us -- instead, create a new one (or copy the old one), remove the irrelevant details, simplify it, and leave the elements (Change the Names to Protect the Innocent) that matter intact.  Post this "example" VI and we'll at least understand the problem, and may be able to make suggestions.
Bob Schor
(4,352 Views)
