Invoke node : export image doesn't work in subvi?
Windows 7 64bit
labview 9, 32 bit
bug alert!!
see attached example vi's
The export image invoke node only works while the subvi is open, if called as a subvi and the subvi is closed this function fails to create an image.
Using the build XY graph express, I have created an xy graph.  Then created an invoke node to export the image of the xy chart.  When i call this vi as a subvi, it works, provided the subvi remains open.  If I close the subvi and run the main vi, no image is created.
Any explanations why this would be so?  Does labview 10 have the same problem?
-Regards
eximo
_______________________________________________
UofL Bioengineering M.S.
Neuronetrix
"I had rather be right than be president" -Henry Clay
(4,168 Views)
That's not a bug, Read This http://forums.ni.com/t5/LabVIEW/Export-simplified-image-failed-in-subvi/m-p/950004
You will get an Explanation and what should be used.
AshwiN,
(4,159 Views)
Accepted by topic author eximo
So the simple answer is, whenever an image is desired from a subvi always use :  invoke node -> get image,  in addition to whatever image gathering code already implemented to force labview to update the image
-Regards
eximo
Neuronetrix
(4,135 Views)
