Iotech DaqBook 260 -> Labview trigger channel
Iotech Daqbook 260 with Labview 7.0 using latest iotech drivers and labview vi's. I'm using a trigger setup similar to the "Daq device main unit advanced analog input example". Data aquires if I use an immediate trigger but as soon as I choose a hardware trigger it comes up with error code 137 (daqAdvArm: Invalid Trigger channel) with all channels 0 to 48. With the immediate trigger, data gets stored in the array output with the first column being the first selected channel. I'm using a dbk45 in the first channel of the daqbook, followed by 2 dbk80's.
Thanks for your time and help, any other info needed please let me know.
Message 1 of 1
(2,543 Views)
