Ip paramters are inconsistent
I am a beginner in LabVIEW, I use a sbRIO 9627 board for a few weeks, I ran simple programs and it went well.
Today, I could not do anything, an error appears as indicated by the image file attached.
I accessed the NI-MAX I found that my board is connected but it is written that "the IP parameters are inconsistent" (see the attached screenshot).
What should I do to solve this?
thank you in advance
(2,706 Views)
It sounds like the port on your PC to which you are connecting to the sbRIO have a set of TCP/IP settings that are inconsistent with the setting of your sbRIO.  They should probably be on the same sub-net, which (depending on your sub-net mask) means the first two or three octets of the IP addresses should be the same (or "close").
Bob Schor
(2,638 Views)
Hi Bob_Schor
thank you for replying 🙂
yes, but i could not change the IP adress !!
in the setting of Network ,it says that the Netwrok is not identified !! (see the file )
 in the second file the IP adress of sbRIO 9627 I'm using , is static and can not be changed.
(2,623 Views)
Hi Karim_Eng,
The article below has some troubleshooting steps when you encounter that error:
"Inconsistent IP Settings" When Using a Real-Time Target in NI MAX
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000P6WdSAK&l=en-US
Jiwhan S.
Technical Support Engineer
(2,581 Views)
