Irritating alt+tab with Labview on windows
Is there any way to prevent Labview from changing the order of the applications when I use alt+tab?
For example, if I want to copy certain information from one application to Labview, I most of the time use alt+tab to switch between the 2 applications quickly. But every time the order of the "alt+tab" is changed by Labview (in fact it puts all the labview windows one after the other), which means that I have to press X times "alt+tab" to come back to my first application. Why does it have to overwrite the default windows behaviour?
Thanks in advance
(3,274 Views)
Maybe "alt+shit+tab" would help, it goes goes backwards...
Also this link might be of interest for you... load the "alt-tab replacement" it's a nice powertoy 😉
Hope this helps
We have two ears and one mouth so that we can listen twice as much as we speak.
Epictetus
Antoine Chalons
(3,271 Views)
I'd recommend reading this thread and throwing your own opinions in...we're actively seeking feedback on how to handle ALT-TAB...
(3,254 Views)
