Is 1.2 version of Modbus library compatible with labview 2010 10.0 ?
I am new to labview am trying to get a .vi written by someone else on a different computer. When I got the .vi and tried to open it, it started looking for Modbus library.
On the website, I only see the 1.2 version of the library which contains libraries for 7.1 to 8.6 versions.
How can I resolve this issue?
Cp
(2,694 Views)
Download the version for LV 8.6.  It should work just fine in LV10.  You may just need to mass compile the VI's before using them.  If you don't, as you use them, it will ask you to save changes because of the upgrade from 8.6 to LV10
(2,683 Views)
Thanks for the accurate response. I just added the files as suggested in the ReadMe.html that came along ignoring the version. It asked me to save changes and that was it. No more Modbus errors.
I won't really be able to test the full function till later this week, till then, I am satisfied with this solution.
Thanks for you help.
Cheers
cp
(2,675 Views)
