Is Ardence RTX required when I use PCI-7831R with labview real-time module for RTX target
I am new in the labview real-time field. I want to use labview real-time module for RTX target on only one desktop. My card is PCI-78331R.  Is Ardence RTX necessary? Why I cannot find my card in the MAX after I configured the RTX?
Thank you very much.
(2,773 Views)
Hi Ziaozhongda,
You must have the RTX runtime engine installed before the LabVIEW Real-Time RTX module will install.  Additionally, you should follow the instructions in the "Using the NI PCI-7831R with the LabVIEW Real-Time Module for RTX" section of Getting Started with the NI 7831R (page 8).
Please see Configuring Hardware for Use with RTX.
Also useful is "How Can I Validate That My PC Will Run RTX?
(2,757 Views)
