Is Fara N 700 PLus PLC is supported in OPC Server Client
Hi all,
I am using Samsung Fara N 700 Plus PLC. I need to read the word registers in that PLC to get some parameters.
Is FARA N 700 Plus PLC is supported in NI OPC Server Clients?
Valliappan.M
(3,948 Views)
Valliappan-
Do you already have an OPC server for your PLC setup? If so, then the LabVIEW DSC module can read its OPC items and bind them to shared variables. I was also taking a look at teh list of drivers included on the Industrial Automation OPC servers disk, but it doesn't look like the Fara is supported:
http://www.ni.com/opc/opcservers.htm
If you do not have the DSC module, you can read OPC items through a datasocket connection. There's an example on this knowledgebase:
http://digital.ni.com/public.nsf/websearch/F92C1F2F7B35105B86256DB200628B24?OpenDocument
Xaq
(3,937 Views)
