Is HTTPS supported on LabVIEW RT?
Can anybody confirm they have used LabVIEW on a RT target to communicate using HTTPS?  If so, how do you do so?
Ashley
(4,277 Views)
Yes, it is possible to communicate with a RT target on LabVIEW via http.
I provide you a link (tutorial), where the method is explained (with images):
https://www.ni.com/docs/en-US/bundle/labview/page/tutorial-creating-and-publishing-a-labview-web-ser...
If you need further assistance, please ask.
Kind Regards,
James.
Greetings and Regards,
James
(4,206 Views)
Accepted by topic author ashesman1
Your inquiry is somewhat unspecific, which is probably the reason for James answer, which I could imagine is not what you were asking for.
While I haven't used that library myself, the HTTP Client library in LabVIEW under Data Communication->Protocols->HTTP Client should support HTTP over SSL connections and is also available in LabVIEW on the RT targets.
Rolf Kalbermatter  My Blog
(4,199 Views)
Thanks.  NI techs have also confirmed HTTP over SSL is supported in current libraries.
(4,175 Views)
