Is LabView for Linux available with the SSP
Hello everyone!
The company where I'm working is considering to transfer our labview test platform from Windows to Linux, we know that there is no demo version, so we are considering to renew our expired SSP, we wonder if the SSP included when buying LabView Professional or full will allow to download the Linux version so we will be able to run some tests but at the same time have the Windows version.
If possible we may be able and consider to have a source code compatible with both OS with code selected for compile depending on OS.
Thanks and Best Regards.
(3,197 Views)
As far as I know you only can have multi platform licenses as part of Volume license agreements. You would likely have to buy two separate licenses here.
Rolf Kalbermatter  My Blog
(3,173 Views)
Hi Abelino, the SSP you have only includes the activation for your Windows software, for Linux you will need to acquire a new license but once you have your SSP renewed, you will have service support for both platforms.
Cesar Ortega
Technical Support Engineering
www.ni.com/support
(3,128 Views)
