Is Scan String for Tokens documented correctly?
I attempted to parse the following string using " as the only delimiter (no operators):
this "is a test" for "you and me"
The first call produced: "this " w/o the quotes.
I expected "is a test" w/o the quotes.
The documentation says the function will return tokens "surrounded by" delimiters. If this is not a bug, I think the documentation should be improved.
W. Brown
(3,188 Views)
some links that might help you ...
http://exchange.ni.com/servlet/ProcessRequest?RHIVEID=101&RNAME=ViewQuestion&HOID=506500000008000000790A0000&ECategory=LabVIEW.LabVIEW+General
http://digital.ni.com/public.nsf/3efedde4322fef19862567740067f3cc/b9db9ccce998d375862569130063d6b9?OpenDocument
http://digital.ni.com/public.nsf/websearch/317a20eb99f64dea86256700005f0403?OpenDocument
(3,188 Views)
The documentation and examples show that the delimiters are used *between* tokens. So with " as a delimiter, the first token would be "this " w/o the quotes. The second token would be "is a test" w/o the quotes.
And, yes, the documentation is a little vague.
Rob
(3,188 Views)
Thank you for commenting on the Scan String for Tokens documentation. We will look into this issue and try to make the documentation more clear about how this function works.
We're constantly striving to improve the documentation, so any specific suggestions you have are welcome. In the future, please send any comments on National Instruments documentation to techpubs@ni.com so we can address your concerns in a timely matter.
Kelly Holmes
LabVIEW Documentation Team
Kelly H
(3,188 Views)
