Is Shared Variable Engine with LV8 an OPC server ?
Hello
Is the shared variable engine with LV8 an OPC server ?
Does any OPC client can acces to Variable Engine OPC server an read shared variable ?
Can I build an installer and deploy my application with Variable Engine OPC server on other PC without LV8.
Thank you
(3,034 Views)
Hi
You can communicate between an OPC serveur and LV8 and use shared variable. To deploy an LV8 exe application, you must have the run time engine installed on the PC without installing LV8. You can create a setup with LV 8 in which you can integrate the run time engine.
Kamal
NIF
(3,020 Views)
Thank you for your answer, but I want use the Variable Engine as an OPC Server for third party OPC client.
That's working on a LabVIEW PC but not if I deploy my application (installer with LV8 engine and Variable engine) an a different PC.
(3,009 Views)
(2,992 Views)
