Is There a way to programmatically extract global virtual channel info from max?
I have a group of DAQmx virtual global channels setup in MAX and I would like to be able to programmatically extract the physical channel information to be included with the data file. In the past I have been able to use traditional NI-DAQ channel utility vi's to accomplish this, but they only see traditional NI-DAQ virtual channels and not DAQmx virtual channels. Is there a group of vi's for extracting DAQmx virtual channel information? I'm using Labview 7.1 with a Windows XP OS.
Message 1 of 8
(4,326 Views)
You should be able to use the channel property node, and wire the global channel constant to it.
Paul
Paul Falkenstein
Coleman Technologies Inc.
CLA, CPI, AIA-Vision
Labview 4.0- 2013, RT, Vision, FPGA
Message 2 of 8
(4,321 Views)
Also the niDAQmx system property node should return an array of all global Channels (as well as other system info)
Paul
Paul Falkenstein
Message 3 of 8
(4,322 Views)
Thanks- That's exactly what I was looking for.
Message 4 of 8
(4,312 Views)
Paul,
I can access basic properties using the approach you described, but do you know how to get the units from the global virtual channel?  Say I had a general appliance for reading in load cells, and I wanted to have the axis labels in a graph show the units of whatever load cell had been selected.
Message 5 of 8
(3,812 Views)
Since this was posted on an older forum post, it will not be visited as frequently. If you repost this on a new forum thread you will get a better response from the community.
Becca B.
Product Marketing
Message 6 of 8
(3,787 Views)
This is kludgy, but it works for AI channels.
Message 7 of 8
(3,750 Views)
That's awesome.  Thanks!
Message 8 of 8
(3,725 Views)
