Is Write JPEG File.vi reentrant safe?
I am making a VI that needs to be reentrant, so all of the subvis have to be reentrant safe.  Write JPEG File.vi is password protected, so I cannot check to see if it is using any local memory, temp files, etc.  Does anyone know or can confirm that the VI is safe to be used in a reentrant VI?
Thanks!
(2,822 Views)
Hi erikg,
I do not see anything in the Write JPEG File.vi that would indicate that it would cause any problems when used in a reentrant VI.  It should be safe for you to include it.  If you have any other questions, please let me know.
Donovan
(2,799 Views)
