Is an event structure right?
   Is the event structure right for what I want to do?
   I have three buttons. When I click Button # 1 this will start a seconds counter (runs until Button # 3 is clicked) Button # 2 will put the current time in an indicator. Then button three is clicked to stop the seconds timer I started with Button # 1 (Button # 1 will have a timeout so it doesn't run forever. Around 1  - 5 minutes Max). So I need to know if a user event structure is going to work for this or is one of the other Labview structures more appropriate for this problem?
   If the event structure would work (I am thinking this would be a better approach for CPU management on an older 933MHz machine). If I am mistaken please let me know. Also if it (event structure) is usable a piece of code demonstrating how I would get it to work would be greatly appreciated.
Many thanks in advance!
Charlie
Everything is Free! Until you have to pay for it.
Message 1 of 25
(4,208 Views)
Sounds like an event structure would be perfect. An event for each button, and a timeout event to service the timer--and you're done.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
Message 2 of 25
(4,182 Views)
Here is some code that does what i think you need
Message 3 of 25
(4,173 Views)
Thanks for the reply.
Charlie
Message 4 of 25
(4,165 Views)
Hey BrianPack,
   This is close however, I need the timer in a loop (I am going to show seconds counter i.e. 1,2,3,4,5,6... etc.) and I need to have it rund until timeout or stop is clicked? If you could help me expand your code to accomodate that functionality it would really help.
Many thanks,
Charlie
Message 5 of 25
(4,155 Views)
Charlie,
So you want the timer to keep running and updating until timeout or button push?
Brian
Message 6 of 25
(4,151 Views)
Brian,
Exactly right....
Charlie
Message 7 of 25
(4,147 Views)
I assumed you don't need button number 2 that you described then if the indicator is free-running.  Does this look about right?
Brian
Message 8 of 25
(4,141 Views)
Charlie,
Also, you may want to add a little wait (like 50 milliseconds) in the while loop inside case 1 to reduce cpu utilization if it is using to much cpu cycles.
Brian
Message 9 of 25
(4,140 Views)
Actually I will be using the second button, because when I click it I want the time stamp put in a seperate indicator, but this is very close and I appreciate your help!
Thanks Very Much,
Charlie
P.S. I will add the 50ms to the while loop. Thanks!
Message 10 of 25
(4,126 Views)
