Is any solution for a retriggable first call ?
Hi everyone,
I am doing labview with some logic stuffs.  I got stuck by exploting a retriggable first call.
Here is the big picture I can see:
 There is a for loop, inside which there is a while loop. The while loop contains a case structure,  the 'first call node'  is connected to the case structure to specify 'true' or 'false'.
What I was expecting to do was refresh the 'first call node' in each iteration of the while loop, but it seems the 'first call node' is a global variable.
I don't know whether there is any other solution to do it, I am thinking of event, semaphore, but I am new to labview and has no idea wheather they would works. Also I am wondering if labview has mechanism like 'stored procedure' in database.
Any idea is well appreciated. Acutally I found one link from Bob's retriggable first call but have no idea how it could works . http://labviewinsights.blogspot.com/2008/09/retriggerable-first-call.html.  it looks too complicated to me.
Kunsheng Chen
(2,850 Views)
Accepted by topic author Kunsheng Chen
The "first call" is exactly that, the first time through that part of the code. You might consider, since this is in a loop, a shift register which is set to T when entering the loop, set to F with in that "first call case", then at whatever point you wanted to "reinitialize" set back to T for the next time through. This will give you sort of the first call effect, although if this loop is exited and re-entered (if it is in a VI that is called from a higher level) you will loose the "first call". Usually first call is used when in say an initialization routine, there are things that are only done once when a program is run, never to be done again until the program is stopped and restarted.
Message Edited by LV_Pro on 02-12-2009 10:41 AM
Putnam
Certified LabVIEW Developer
Senior Test Engineer North Shore Technology, Inc.
Currently using LV 2012-LabVIEW 2018, RT8.5
LabVIEW Champion
(2,844 Views)
