Is anyone interested on a simple LabVIEW ICON EDITOR
Hello LabVIEW users! Often, when you develop a project, you need a lot of time in developing VI and Sub VI-Icons. This tool helps you to create fast vi icons for all your vi's. This version does not support direct access to libaries. (Maybe in the next release) However, I hope that it is useful for you!
Please send me any comments and tipps and tricks...
(I know, that the code could be much bether, however, it works...)
(2,779 Views)
Hi mc-hase
I had no chance to test your utility, but it seems very nice and usefull.
For which department do you work at Ruag ?
Doc-Doc
http://www.machinevision.ch
http://visionindustrielle.ch
Please take time to rate this answer
(2,779 Views)
So just run the VI, choose a directory and modify a VI Icon. The big advantage is, that you can choose from color -sets (you have to make your one's) and that the informations are getting saved with the Vi. So the next time you are editing a Icon, you see the colors and the text etc...
By the way, I work in the "Technik" departement in the Center for Aerodynamic.
(2,779 Views)
