Is here a property node "one change" for a text ring?
In my LabVIEW program needs to be an action when the item of a text ring changes. Namely there has to be a reset of a value when someone changes the item of the text ring. Can I use a property node for that?
Thanks for helping!!
Greets
Pieter
(2,614 Views)
Do you know the event structure?
Greetings from Germany
Henrik
LV since v3.1
(2,611 Views)
I never used it before, can you give me an exemple?
Thanks!
(2,606 Views)
I found an exemple but is doesn't work.
(2,594 Views)
I solved my problem with a shift register and a case structure. I compare the new value of with the old one. When these are different, the case structure resets a value.
(2,580 Views)
Hello Pieter,
As Henrik already said, it sounds like the Event structure is a better option here.
Maybe you can share the example you tried to see if we can help you?
Cédric | NI Belgium
(2,550 Views)
