Is is Possible to count any particular address bit of Siemens PLC?
Dear All
i have project in which i monitor shared variables of Siemens PLC.
i stuck on to count memory address from PLC.
i want to count any particular address say "M0.5"  that how many time used in whole project.
is it possible to count that from labview and display count value as a integer on front panel of my labview project?
Please help
Asif
(3,069 Views)
Hi Asif,
Just to clarify, are you asking if you can count the number of times a value is read from a particular memory address while running your project? Or are you asking how you can count the number of explicit references that have been defined for a specific memory address in your project?
Additionally, what is the specific model of your PLC and how are you communicating with it?
Best,
Applications Engineering
(3,014 Views)
You might be able to count the instances of a specific shared variable with scripting. It wouldn't be easy. And if you succeed, it will not work in an executable.
(2,993 Views)
any idea how to write script?
(2,980 Views)
Do you know how to use Google search? Just search for "VI scripting" or "LabVIEW scripting" keywords.
One hit:
https://www.ni.com/docs/en-US/bundle/labview/page/common-vi-scripting-tasks.html
(2,970 Views)
