Is it Possible to change the Name ' ASRL3::INSTR' to COM3 instead, in a' VISA resource name' Control ?
Hi all.
Is it Possible to change the Name ' ASRL3::INSTR' to COM3 instead, in a' VISA resource name' Control.
see attached  pic.  is there a control  propertie that can change this View eks.  "ASL3::INSTR"  To "COM3"?
 HFZ
HFZ
Message 1 of 9
(8,664 Views)
 With Measurement&Automation explorer you should be able to modify the serial port ALIAS to "COM3"
see jpg
CLD - Labview Certified Developer
Message 2 of 9
(8,649 Views)
Yes that is possibly right, but that will only be for that port.
I would like to change the VISA formatting The Control views. so other ports also are changed automatic.
Ex.  if my program is running on a PC with 3 ports, then in the controllers Window for the VISA Resource, it wil display
ASL1::INSTR
ASL2::INSTR
ASL3::INSTR
There must be a propertie for the controller or so ?
HFZ
HFZ
Message 3 of 9
(8,641 Views)
This document shows how to use the VISA alias utility.
Message 4 of 9
(8,638 Views)
Sorry but the only way I know to change that kind of alias is modifying the key in "visaconf.ini".
Message 5 of 9
(8,635 Views)
This is exactly what MAX will do when using the tool that is described in above linked document... Obviously, you can edit this file (take care to the exact syntax and don't forget to update the number of aliases) but it is much more confortable and secure to use MAX.
Message 6 of 9
(8,633 Views)
This configuartion is set up, but when Running the application I only get those long Port names.
Could itbe that it only comes trough when making an .exe application?
HFZ
HFZ
Message 7 of 9
(8,612 Views)
Do you run the application on your development computer or on another machine ? Are the aliases (eg COM3) displayed in the development mode ?
Message 8 of 9
(8,591 Views)
Antea,
Your user icon doesn't show up because you hosted it on some 3rd party website we dont' have access to.  Post your icon as an attachment to the Icons Thread
Then have you user profile point to the file attachment at that message thread if you want people to see it.
Message 9 of 9
(8,562 Views)
