Is it better to use Invoke nodes or property nodes to set/get control values?
I have a series of VI's that run in parallel, each to manage different functions- pumping, sensing, a fluid flow model, an experiment generator/runner.
These need to exchange data, which I am currently doing using invoke nodes (that are all in subVIs), using methods "Set control value" and "Get control value". I find that every now and then (perhaps 1% of the time) the data isn't exchanged correctly and therefore the system doesn't work. I can imagine how "set" could go wrong if they happen simultaneously, and can devise ways of preventing this. However, the "Get" method suffers from the same problem. This is a major problem, because I want to leave it running for several hours.
I could in
principle achieve the same thing using property nodes and find myself wondering if this might be more reliable. But I don't want to change over only to find it makes no difference!
Can anyone advise?
(3,116 Views)
Use functional globals, notifiers or ques.
Try to avoid setting values using property nodes (even locals are better in most cases). If you ever want to build an application of your code the set control value method is not supported(!), so go for functional globals or something that is.
(3,116 Views)
You can use some kind of syncronization such as queues, occurances, or notifiers but I think the easiest way would be to create and action engine. This was only one action can execute at a time avoiding a "race condition". Possibly a write action and a read action might help. You also can add queues or notifiers into this concept. hope this helps.
BJD1613
Lead Test Tools Development Engineer
Philips Respironics
Certified LV Architect / Instructor
(3,116 Views)
Hi Mads,
the help of LV 6.1 states Get/Set Control Value is available in runtime. If it really does not work is the help wrong or is it a bug?
Waldemar
Waldemar
Using 7.1.1, 8.5.1, 8.6.1, 2009 on XP and RT
Don't forget to give Kudos to good answers and/or questions
(3,116 Views)
Heey, you are right! I'm outdated:-)
It did not use to be, but I just tested it in LV7 and it works fine.
If it sometimes fail though, as described here...functional globals, notifiers etc. may still be a better solution.
(3,116 Views)
