Home
Community
Discussion Forums
Most Active Software Boards
Topic
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
Is it possible in LabVIEW to get the actual adress out of the adress bar of a open Windows Explorer window ?
semmar1
Member
11-02-2004
11:08 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
I try to get the path out of the adress bar of the Windows Explorer in Labview. How could I get access to this information.
0
Kudos
Message
1
of 4
(2,644 Views)
Reply
Re: Is it possible in LabVIEW to get the actual adress out of the adress bar of a open Windows Explorer window ?
ThSa
Active Participant
11-04-2004
02:41 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
you can work with the user32.dll to get the information!
In the attachement you can find an example...
regards,
Thomas Sandrisser
NI Germany
WindowID.llb 54 KB
0
Kudos
Message
2
of 4
(2,643 Views)
Reply
semmar1
Member
Author
11-04-2004
03:02 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
thanks for your answer, but if I understand the example right, you get the window title.
I need to get the adress or better the file path wich is shown in the adress bar of the Windows explorer.
Regards
Martin
0
Kudos
Message
3
of 4
(2,643 Views)
Reply
ThSa
Active Participant
11-04-2004
03:47 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
with this example you get the Window ID!
The window title is needed for the identification!
If you want the file path of the adress bar, you should ask microsoft for further informations!
regards,
Thomas Sandrisser
0
Kudos
Message
4
of 4
(2,643 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
