Is it possible that using property node to delete or add items?
I am writing a program for Sudoku. I used Enum for each numbers.
Is it possible that using property node to delete or add items of Enum variables?
Fchencn9
Message 1 of 13
(4,292 Views)
HI fchen the enums don’t allow changing the string while in runtime, but you can use Text Rings and menu rings for this, you can change the value and the string while in execution
If you want to stick with enums you can use the disable items property node here is an example.
 Best Regards
Benjamin C
Principal Systems Engineer // CLA // CLED
Message 2 of 13
(4,291 Views)
Thanks, BeCeGa.
I will test it and report here.
Fan
Message 3 of 13
(4,287 Views)
     I am not able to open your example
because I have only Labview 8.0.
Could you save your sample to version 8.0?
thanks,
Fan
Message 4 of 13
(4,261 Views)
How can I transfer the information in property node, for example, which items are diabled,
 from one Menu Ring control to another one control?
1. Now I am using Menu ring in 9X9 to represent each numbers in Sudoku.
And I can disable desired items using property node of each menu ring control.
2. To check if there are repeated number in row or column, the 9X9 numbers
are converted to a 2D array,each row or column in 1D array.
3. I want to diable items of elements in the array because it is easier
to index each number. THen I want to copy the numbers in the array
with some items diabled back to menu ring controls.
My questions are:
1. The element in the array is no longer menu ring type. How can I disable its items?
2. I tried to pick out a element and wire it to a menu ring indicator.
   I diabled some items of the indicator. How can I transfer the diable information
back to the original menu ring control?
Fan
Message 5 of 13
(4,250 Views)
Hi Fan,
Can U attach Ur VI saved for 7.1, or atleast can U post a screenshot of the FP to get a clear picture of what other controls re U using ?
- Partha ( CLD until Oct 2027 🙂 )
Message 6 of 13
(4,235 Views)
OK. Here attached is my program.
The purpose is to simulate the Suduko game
and provide suggesting while users are playing the game.
After each choice the user made, the program
assumes this choice is correct and changes the
candidate numbers ( a few numbers for choice) in other
positions ( to avoid repeating number in each row/column/3X3 area).
Fan
Message 7 of 13
(4,225 Views)
Hi Fan,
Can U attach the missing sub-VI also ?
I'm not able to analyze the code... Smiley Sad
Message 8 of 13
(4,209 Views)
Yes. Forgot the Sub-VI.
Here it is.
Message 9 of 13
(4,194 Views)
Hi Fan,
I'm also having trouble interpreting this VI... the use of nested, stacked sequence structures and local variables really breaks the LabVIEW dataflow paradigm and hurts legibility.
Might you be able to refactor this and ask specifically what sections we can help you with?
-Sam F, DAQ Marketing Manager
Message 10 of 13
(4,161 Views)
