Is it possible to build a exe with labview7.0 that contains simulink dll created using Simulation Interface Toolkit
Is it possible to a exe with labview7.0 that contains simulink dll created using Simulation Interface Toolkit
(2,565 Views)
Yes. You will need to add the dll as a support file. In Application builder you will see the Source Files tab. In this window is a button to Add Support Files. Click this button and navigate to the dll to include with your executable. Continue building your application. When you run you executable it should now be able to find the dll.
Joseph D.
(2,565 Views)
