Is it possible to build a project with Labview 2010 on a Windows XP system, that is useful for a system with windows 7 on it?
Hi there,
I am planning to use Labview 2010 in a short time.
But before I'm going to use it I have some questions.
  1. I know it is possible to run Labview 2010 in an XP environment. But is it also possible to, when running Labview 2010 on a XP system, to build a project to a version that is useful in a Windows 7 environment?
  2. Or do I have to run Labview 2010, when I want to build a project that is useful on a Windows 7 system, on a system with Windows 7?
Please give me some information.
I hope to hear from one of you soon.
Kenny
(2,962 Views)
You can build an exe on windows XP with LV2010, and run it on windows 7.
V-F
(2,960 Views)
Does Labview 2010 automatically make a file that is useful for Windows 7 or do I have to make a selection for it?
Because it's possible to run Labview 2010 on Windows XP, Windows Vista and Windows 7.
Kenny
(2,956 Views)
Accepted by topic author Cheese11
the file (.exe) is both compatible with xp and seven, no need to change anything...
Regards
V-F
(2,950 Views)
Is it possible to build a project with Labview 2009 on a Windows XP system, that is useful for a system with windows 7 on it?
Thanks.
Philippe B.
Certified Associate Developer / Dépt Moyens d'essais
www.ingenia-system.com
(2,862 Views)
Same answer. The binary file will run. BUT... Windows 7 has stronger protection on certain folders, so if you are trying to do certain things, like writing directly to the C:\ drive, or to the C:\Program Files, or to the registry, you will get errors. This is not a LabVIEW issue, but an operating system issue.
(2,854 Views)
