Is it possible to built an application, having some project conflicts
I use LabVIEW 8.6 and have some subversions of my projects on the development PC. Opening the subversions I get sometimes projectconflicts. Is it possible to built an application without solving the project conflicts? --> like LabVIEW7 which use the current VIs in memory to built application.
(2,459 Views)
I know this isn't actually an answer to your question, but have you looked into using the conditional disable diagram structures?  That might be a good way for you to maintain multiple versions without generating conflicts.  From personal experience, I can also tell you that plug-in architectures based around VI server are another approach that works pretty well.
Jason
(2,445 Views)
