Is it possible to call an executable of compiled c code from within LabVIEW?
I can compile 'genesis' (the name of the code we are planning to use) under unix: it produces an executable which can be
linked to user-constructed c files which contain specific crossover and/or
mutation strategies, so once a user has the executable, it is not
neccesary to re-compile the main GA everytime a user mucks around with the
combination rules. I think that a question is, can you call the (or any)
executable from within LabView?
Alan Homer
(2,380 Views)
You can call executables using the System Exec VI, which can be found in the Communications palette.
___________________
Try to take over the world!
(2,375 Views)
