Is it possible to change the border color on a case structure depending on the case input? For example, using a True/False case structure, I would like the case border to be green when true, and red when false. Thanks for any help on this.
I believe that the actual case border can only be one color regardless of the true/false case. However, you can color the background of the inside of the case different for each case.
Mark
(3,114 Views)
Hi Mike,
if you have LV 6 and further, there is a 'side' solution:
when you connect an Error control to a case structure selector, the borders become red or green depending whether there's an error or not.
If you really need colors, you can force the state of a fake error control (or error cluster) with a TRUE/FALSE control.
Good luck,
Alberto
(3,114 Views)
