Is it possible to change the colour of the z-scale for intensity graphs in LabVIEW 7.0?
Sorry if this seems like a lame-brain question.
I'm trying to change the colours of the z-scale used for an intensity graph (LabVIEW 7.0). Maybe I'm blind and the property I want set is accessible through the right-click menus or the property window, but I can't seem to find it.
Is it indeed possible to change the colour of the z-scale? Or is the colour fixed?
(2,699 Views)
Hi Victrick,
yes it is possible to change the color of the z-scale of the intensity graph.
At the side you see the color bar, click there right and disable the color interpolation. Then you will see some color filled areas and the value of the axes written at the side of the color bar at the borders where the color are chaninging. The trick is now not to click at the color areas changing the color but instead clicking on the values written at the side of the color bar. Then you will get an menu item at right clicking like change color where you can chose some own color out of a color palette for the color area above the value.
(2,699 Views)
