Is it possible to change the names of the pages on a registerelemnt programatically?
Yes, it is.
1. Deactivate the option "Make Page Caption Match Label" (see attachment), so that you're able to set the caption
2. Create a property-node of your tab-control, using the property "pages" (array of references)
3. Using this references you can acces the property "TabCaption"
Hope this helps.
Thomas
Using LV8.0
Don't be afraid to rate a good answer... 😉
Message 2 of 8
(3,675 Views)
@becktho wrote:
Yes, it is.
Hope this helps.
Thomas
Hi Thomas,
I´ve did it your way, but i get an error back, see attachment.
I says, the property could be set only in editing mode.
Message 3 of 8
(3,649 Views)
Now with attachment...
Message 4 of 8
(3,647 Views)
Could you send it as a LV 7.0 vi?
I still use LV 7.0.
Thomas
Using LV8.0
Message 5 of 8
(3,644 Views)
Jepp,
here it comes in v7.0
Message 6 of 8
(3,637 Views)
Ok. In the vi you sent me I saw that you were using the wrong property (PageLabel instead of TabCaption). I also saw that you're using a german version on your screenshot.
So try the attached vi (I just changed the property to TabCaption).
Hope it works now.
Thomas
Using LV8.0
Message 7 of 8
(3,633 Views)
Hi Thomas,
thanks for your help, it works now.
I´m working on a function to select the language of my application. I had the same problem to change the label of a control, it´s only possible to change the sub-title in runtime.
It´s the same with the registerelement...
Thany you!
Message 8 of 8
(3,630 Views)
