Is it possible to change the same shared variable from several running vi clones?
My problem is that I want to change the same shared variable through several clone vi's ( reentrant option ) which running simultaneous.
I want to change this specific shared variable from any of clone vi's which running together with all others clones.
It seems that it is immposible.
Any suggestions?
(2,433 Views)
Yes but you will probaly not like the results if you did.
Other options include
1) Action Engines - Solid corners-stone of LV development going bacfk to LV 2 and are simple to design implement and trouble shoot. May be lacking if you clones have to point a different AE.s
2) Use semaphorse to protect the SV but this will only work within a single process context.
3) Sinlge element queus - fast and flexible but take more work to understand.
4) DVR _ Data Value refereince creates shared memory buffer accesable only via inplace operations.
Have fun!
Ben
(2,428 Views)
