Is it possible to check a file is add in the build file?
Is it possible to check a file is add in the build file? For example ../APP.exe/Main.vi. I need a subVI that allows the same action of "Check File", but with the .EXE file build. Thank you.
(3,437 Views)
There is, but why?  Are you trying to ensure that a VI is added that you are opening by a reference to by path?  Because if you are you should be using a static VI reference.  Here is an old example.  Then it doens't matter where the VI is just that it is in memory.
http://forums.ni.com/t5/LabVIEW/building-an-executable-with-vits-with-Labview-2011/m-p/2384984#M7404...
Now if you really do want to know if a VI is in the EXE you can try to open a reference at that path and if it throws an error it isn't there.
(3,423 Views)
If it is that important, use the Always Include on the executable build spec.
GCentral
(3,381 Views)
OK thank you very much. I have different subvi, which are inserted in subpanel. For some subVI have a file menu .rtm. My intention is to add the menus build and check for a partner for that file menu, for this, I have the same name subvi and menu. Therefore, wanted to know if Is it possible to check a file is add in the build file? the answer is NO. but there is any alternative to this?.
(3,354 Views)
This sounds like you are trying to make a plugin architecture.  You might want to look into using Packed Project Libraries.  Then you can just check to see if that PPL exists where is should be and throw an error if is doesn't.  This would also allow you to add more plugins simply by copying the PPL to the right location without rebuilding your entire application.
GCentral
(3,318 Views)
