Is it possible to check if all parameters are connected while running?
i have a Vi with one input "Text" and another parameter "bool".
Is it possible to check if the bool-parameter was wired if called from another vi?
Reason:
If not wired i want to write only the text to a logfile
and if wired i want to write a text + the state of the boolean value.
So something like a property "ValueIsWired" that can be used then with a tru/false case to generate different outputs.
Thx
Message 1 of 8
(3,091 Views)
Hey,
you could set the input of the sub VI to "recommended" and set the string you want to write if not wired as default (right click the control -> Data operations->make current value default ) for the control. So if it is wired it will take the string you wired, otherwise it will work with the default one.
CMW
Message 2 of 8
(3,088 Views)
Ahh, I missed the boolean, ...
but the idea remains with the default values.
Regards, CMW
Message 3 of 8
(3,087 Views)
As far I know there is no property available. You can do it in another way, instead of giving Boolean as terminal provide a variant input and check whether it is empty or not.
Message 4 of 8
(3,072 Views)
Reason:
Thx
Default bool to False, only write State if True. 🙂
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 5 of 8
(3,042 Views)
This is a case where I would not favor a boolean.  You can't tell if the value was wired with the default value or if it was unwired.  Luckilly, a signed integer terminal with a -1 default would offer better options.  (The Caller shoud probably never pass in a negative value)  You simply need more than two possible values.
Message 6 of 8
(3,035 Views)
I totaly agree with Jeff.
You usually use self defined default values(differents from the LV default value for every datatype) for sub-VIs for the case of unwiring these terminals.
The other possibility is using the recommended terminal setting.
For the boolean terminal, two values aren't enough. Many VIs use these '-1' default value for detecting a wired terminal.(-> timeout, DAQmx read).
Philipp
Message 7 of 8
(2,998 Views)
If you want to write the status flag, whether true or false, you'll need an extra input "include status".
/Y
Qestit Systems
Message 8 of 8
(2,989 Views)
