Is it possible to convert the .vi's code into the C/C++ code
Hi All,
              I want to know that is it possible to convert .vi file into the .c or .c file? by that i want to know that is it possible to convert the LabVIEW code into simple C or C++ code?
Thanks in Advance,
Nishant
Message 1 of 8
(3,834 Views)
Yes, LabVIEW embedded can do that, but why would you ever want to convert your code from G to C?
Ton
My LabVIEW Ideas
Message 2 of 8
(3,828 Views)
     Actually we want to first simulate our hardware scenario in the LabVIEW and then we want to port that code into the processor memory and to port this into the processor memory it requires the pure c based code rather than .vi code, that's why i want to convert it into the C code.
Nishant
Message 3 of 8
(3,822 Views)
As Ton mentioned... be prepared to spend about $11,000. You should also be aware that the LabVIEW Microprocessor SDK (as it's called now - gotta love those marketing folks) does not support all of LabVIEW's functions.
Message Edited by smercurio_fc on 08-09-2007 08:54 AM
Message 4 of 8
(3,804 Views)
Message 5 of 8
(3,794 Views)
Message 6 of 8
(3,794 Views)
How big is the project? I can tanslate from labview to C++
Message 7 of 8
(3,789 Views)
        Actually we are in the anlysis pahse, so even we are not clear that how big it will be.
Nishant
Message 8 of 8
(3,773 Views)
