Is it possible to create a 1 D array with the "build array VI"? when receiving random number
Thank you again for your quick reply please let me explain using mathematical equations as it will make more sense to you.
I have two functions (X1) and (X2), Then I take the FFT of both functions, fx1=fft(X1) and fx2=fft(X2)
Then I perform the cross correlation between both function which is : fX1X2 = fX1.*conj(fX2) ;
Then I perfom a normalization of the cross correlation
fx1x2phat = fx1x2./((abs(fx1x2)).^0.5); My question is: how do I do if I want to change the Value 0.5 from "0.1 to 0.9" with a step of 0.1
In Matlab the code would look at the following.
fx1=fft(x1);
fx2=fft(x2);
fx1x2 = fx1.*conj(fx2);
A friend of mine also told me that I could directly put my Matlab code in LabView, but I do not know how to do it.
Thank you Israel
Message 11 of 16
(726 Views)
fx1=fft(x1);
fx2=fft(x2);
Thank you Israel
Message 12 of 16
(725 Views)
Don't overcomplicate things. LabVIEW has a function for crosscorrelation.
Message 13 of 16
(718 Views)
altenbach,
Thank you very much for your feedback but you have forgotten a very small and simple details.
The cross correlation you have presented to me is performed in the time domain, therefore require more storing resources than if it was performed in the frequency domain.
If someone can just explain to me how to use LabView to perform the computation presented in my previous email, I will be more than grateful.
To Be honest and fair, you guys are amazing.
Thank you
Israel,
Message 14 of 16
(708 Views)
@israel.haifa wrote:
@altenbach
Did you even read the help page I was linking above? The function is polymorphic and you can easily select frequency domain algorithms (it is even the default!!!).
Message 15 of 16
(703 Views)
Hello altenbach,
I would like first to start by thanking you for your reply, Why don’t you take the example giving to us by  “Đặng Huy Hoàng”
Take two array of the same set of number: 1+1i , 2+2i, 3+3i, 4+4i then the conjugate will be 1-1i , 2-2i, 3-3i, 4-4i
Then do the cross correlation in the frequency domain using  “Đặng Huy Hoàng” approach and your proposition and see if the results are the same. Please do not even worry about the normalization first.
Many thanks for your cooperation in this matter.
Israel
Message 16 of 16
(677 Views)
