Is it possible to create a GUI displaying foot pressure data?
We are using Labview 8.5 student edition and we have a project where we are monitoring varying pressures on a foot.  We are using 4 flexiforce sensors placed on a foot pressure pad that output voltage and are running these voltages into the 4-channel WLS-9219 DAQ.  What I am wondering is this:
After browsing the available VI's within labview, is there a way to create a custom one where I display a "foot" on the screen, and as a person applies a force to a  particular sensor (or multiple sensors), this "GUI" shows "redness" area denoting a harder pressure, as well as displaying all the values of the load as it varies?  I am also wondering if there is a way to have Labview interpret a voltage signal (ex. 300mV) as a force (ex. 30 pounds).  Any help or ideas with this is appreciated!!
(4,052 Views)
You could use an intensity graph for your display.  Past an image of a foot outline over the graph.
Scaling is simply multiplication.  The VI does not really care whether a number is a voltage or a force.  You can also assign units to indicators.
Lynn
(4,048 Views)
You would just need to read the instruments manual.
It would say something like this:
Pressure output is between 0 lbs and 100 lbs .
The output sent to the computer is between 0- 10mV
So you would read in the voltage, then multiply by 10 to get the pressure.
Cory K
(4,045 Views)
Thanks for the tips.  How exactly do you get the Intensity Graph to appear from underneath a picture pasted into the Front Panel?
Let me tell you exactly what we have and what we're trying to do:
We have sensors that will monitor the load applied to that area of the foot and measure that in volt.  We are using four such sensors and want to create a display in LabView where data is sampled at 5 Hz (and thus refreshes that often).  We are looking to display real-time voltage or force values, a line graph for each sensor (which we have) and then a seperate display of an entire foot.
Say we have 4 sensors placed in 4 different areas, for example, on the heel, ball, sole, and under the big toe.  When a person steps on our sensors, each sensor will read different values.  What we want on the Front Panel is a diagram of a foot and a visual representation of the loads being applied to that location, most likely using a color notation.
I looked into Intensity Graphs, and what I found was that they require a "matrix" of values to represent a grid-like area.  What we are sort of looking for a "circle" to appear around each sensor location on the foot, and the size of the circle will increase/decrease based on the magnitude of the force being applied.  It doesn't have to be a "circle" per se, but a similar effect will do.  Any idea how this can be done?
(4,001 Views)
Two methods come to mind.
1) Use customized color boxes for each pressure point. Set their color and size based on measurement.
2) Use a Picture control to render the readings using circles at the appropriate locations.
Just trying to help,
Ben
(3,995 Views)
Sounds like an interesting project. You could use a simple Boolean LED as well, and set the Button size accordingly. See attached sample (LV 8.2) for simple demonstration.
Lots of possibilities - depends on how fancy you want to get.
(3,970 Views)
