Is it possible to create a new task while VI is running?
Is it possible to create a new task while VI is running? or to create a new task is it possible to run DAQ Assistant in runtime.
(2,653 Views)
It is possible to create a new task while the VI is running...and for this you can use the DAQmx Advanced Task Option>> DAQmx Create Task.vi. I don't think you can call DAQ assistant from your VI.
BR
(2,642 Views)
Ok, how to launch DAQ Assistant when VI is running?
(2,636 Views)
Thanks Kallis, but the task created by "DAQmx Create Task.vi" destroys when LabView exits. I actually wants to give option to user to permanently create a new task during runtime. So, is there any way to launch DAQ Assistant during runtime?
(2,633 Views)
