Is it possible to create a string indictator that updates when a new event occurs? That is, without clearing a string indicator, add another string to the indicator like when an additional failure occured.
Hi Christopher
Just read the value of the string indicator (either from a local variable or a property node) and append your error-string. Wire the result again to the indicator (again either to a local variable or a property node).
Thomas
Using LV8.0
Don't be afraid to rate a good answer... 😉
(2,690 Views)
