Is it possible to create several cursors on a graph by importing a table of points?
I would like to create several drag free cursor lines on a graph based on points on an already prepared table. Also, when I drag cursors to a new position, I would like to be able to generate a modified table of points when the cursor position is changed.
Basically I want to generate cursors from a table and also be able to update that table ( or even create a new table) based on the positions of the cursors or by changing cursor positions.
Does anyone have an idea of this is possible and how it maybe implemented?
Thanks .
[BADGE NAME]
(2,894 Views)
This can give you some starter idea:
https://decibel.ni.com/content/docs/DOC-19383
(2,871 Views)
Thanks very much. Greatly appreciated. I am also trying to rotate a graph window by 90 degrees ( or alternatively reverse the paraneters so that the X becomes Y, and cice versa. I have a added a "transpose array" property mode but has not changed anything. Any directions on how to achieve this would be greatly appreciated. Please note that I am new to Labview in case you find this too easy 🙂
[BADGE NAME]
(2,844 Views)
