Is it possible to download the LV code to pda in LabVIEW evaluation version?
Is it possible to download the LabVIEW code to pda in LabVIEW evaluation version?
For example:
I want to select New » Targets and Devices from the shortcut menu to open the Add Targets and Devices dialog box as shown in the below Figures.
Is it possible to do the same in evaluation version of LabVIEW 8.0
(3,251 Views)
Prasada,
In order to target a PDA device, you will need to have the PDA module installed. Fortunately we do have evaluation software also available for the LabVIEW PDA Module 8.2. Once this has been installed, you should be able to target your PDA device. Please post back if you experience any trouble. Thanks,
Mike D.
Message Edited by Duffman Says: on 11-21-2006 04:59 PM
(3,235 Views)
