Is it possible to embed DAQmx in Installer(created by Application Builder)?
The good thing of Installer (created by application Builder) is that it also integrates LabView Runtime Engine along with supports like Serial port support, Port I/O support etc. Due to which one can install the application developed by Labview on any system wheather that contains Labview or not, as the engine required by that application also gets installed.
But problem with my application is that it uses DAQmx related stuff, so I have to install DAQmx 8.0 prior to running my application installer on any system. Is it possible that the DAQmx related stuff required by my application also gets install through same installer as it installs LabView Runtime Engine, so that the distribution of my application donot require the complete installation of DAQmx.
(2,641 Views)
You need to use LV 8.0.  You can add NIDAQ to your installer in LV 8.0.  In previous versions I do not think it is possible.
see: http://zone.ni.com/devzone/conceptd.nsf/webmain/5ADBC06AC32E508A8625706E0062EBD1
Matt
Matthew Fitzsimons
Certified LabVIEW Architect
LabVIEW 6.1 ... 2013, LVOOP, GOOP, TestStand, DAQ, and Vison
(2,629 Views)
Thanks alot
(2,622 Views)
