Is it possible to find out if a digiatal control is an integer or a double value?
When I have the Reference to a Digital Control, how can I find out the Representation of it's value(e.g. Double, Integer32,...)?
Message 1 of 10
(5,193 Views)
Activate VI Scripting (LV Options) and you will have access to a property called "Representation"....
Please note that you should only read this property for running VIs!
Norbert
Norbert
Expert: Geometry
Message 2 of 10
(5,184 Views)
Does it matter? You can convert value from int control to double, it has enough precision, you will not loose data.
Message 3 of 10
(5,161 Views)
@Alexander: That is not true for I64/U64. Also I want to save the data to file and save memory.
@Norbert: I will try this out. Is there a reason it is not possible to get the representation without VI Scripting?
Message 4 of 10
(5,115 Views)
@romankoch wrote:
@Norbert:[...] Is there a reason it is not possible to get the representation without VI Scripting?
Honestly, i don't know. I assume some legacy decisions of the LV R&D team.....
Norbert
Norbert
Expert: Geometry
Message 5 of 10
(5,111 Views)
Accepted by romankoch
C:\Program Files (x86)\National Instruments\LabVIEW 2015\vi.lib\Utility\Data Type\Get Type Information.vi
Message 6 of 10
(5,067 Views)
Yep. The location and the VI paul_cardinale suggest works. Kudos paul!!!
Though there is no Data Type Folder in my PC (Running Win7 and LabVIEW 2014)
C:\Program Files (x86)\National Instruments\LabVIEW 2014\vi.lib\Utility\GetType.llb---->Get Type of Control.vi will help you to determine the Representation of the reference.
-John Theodore
Certified LabVIEW Architect, Certified TestStand Architect
Message 7 of 10
(5,057 Views)
I'd like to know why you would need to know.  This is for my own education, since I have no idea why it would be useful.
Bill
CLD
(Mid-Level minion.)
Message 8 of 10
(5,021 Views)
@billko: I write the value of the control to an config file. So I need to know if I write a double or an integer. Until now I always used a double, but it doesn't look nice, when integer values get displayed with fractional digits.
Message 9 of 10
(4,962 Views)
You can format the value yourself and use Write String key instead. With Format Value and format specifier "%#g" you'll cut trailing zeroes, which should make it general enough.
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 10 of 10
(4,954 Views)
