Is it possible to generate a waveform without using DAQ?
hi, i want to ask if it is possible because i am only trying to run a demo VI without the hardware. Thanks!
(2,674 Views)
Hi txrxmo,
yes, that's possible!
Spoiler
In case you want to know how: There's a whole functions palette with functions to generate waveforms...
(2,668 Views)
If you want to simulate hardware, check this out: NI-DAQmx Simulated Devices.
steve
Founding (and only) member of AUITA - the Anti UI Thread Association.
(2,654 Views)
Go to the Signal Processing->Waveform Generation palette.
(2,647 Views)
