Is it possible to generate code (as C or C++ code) from a LabView diagram
Thanks.
Hassen
(2,908 Views)
No
although it is possible to generate VHDL code
with the correct inifile setting. This VHDL code is useless because the required libraries to link with the code are not available.
greetings from the Netherlands
(2,908 Views)
Hi Hassen;
LabVIEW is an alternative to traditional text-based programming languages. It is not an alternative way to come up with text-based code.
If you created a function in LabVIEW and want to use it in another programming language, you can convert it into a dynamic-link library (.dll file) and then call the dll from your code. You need LabVIEW 6i and Application Builder.
The following tutorials explain how to do that:
Building DLLs in LabVIEW 6.0
Calling a DLL from Microsoft Visual C++ that Was Generated by LabVIEW 6i
Best regards;
Enrique
www.vartortech.com
(2,908 Views)
