Is it possible to get more decimals with the Excel Get Data.VI?
Like the title says, is it possible to get more than 2 decimals with the Excel Get Data.VI from the Report Generation Toolkit? Writing more decimals is no problem but if I get the data from the Excel file it will only give me more decimals when I manually fill in the data in the excel sheet. If I use the RGT to write the data, it won't return more than 2 decimals.
*The data that only returns 2 decimals is created with a formula in Excel
(2,672 Views)
Just a thought without really looking at it, but you could always get the data as a string and then convert to your desired precision afterwards.
CLA
(2,629 Views)
I don't really know how or why, but I tried some different things in the Excel Get Data.VI and suddenly I get more decimals, but as far as I know all the settings are back to original.. Using a double now and it works for what I need, thanks anyway!
(2,602 Views)
