Is it possible to get tick count timer of output in nano-seconds or microseconds
The tick count timer available in Labview gives output in milliseconds. Is it possible to get same type of function which could provide time in nano seconds or microseconds.
Message 1 of 10
(8,649 Views)
Use the windows (if you use windows) API QueryPerformanceCounter. The accuracy is hardware dependant, but on modern computers it should be faster then 40MHz. You can query the frequency with QueryPerformancyFrequency. Both API's are in Kernel32.dll
Wiebe.
"Anderomeda" <x@no.email> wrote in message news:1139202648493-320567@exchange.ni.com...
Message 2 of 10
(8,636 Views)
I have the same problem but I don't understand the answer. What is this API and how do you use it with Labview?
Message 3 of 10
(8,413 Views)
Nobody knows?
Message 4 of 10
(8,394 Views)
The Windows API is a set of DLL functions and you can acces it via the call library function node. I made a VI which calls the right functions for you.
Greets, Dave
Greets, Dave
Message 5 of 10
(8,374 Views)
Thanks but I can't open it I use Labview 7.0 and this VI seems to be made for version 8.2. Could you just give me a way to open it please?
Message 6 of 10
(8,371 Views)
Here are some LV7.0 VIs that can be used to query for the processor tick count.  Resolution is your processor tick interval.  They will not work on non-Intel compatible machines or on processors which do not support the tick count attribute (e.g. the original pentium).  They are Windows only.  Note that even though they give you high resolution, the accuracy is very suspect.  Windows is a multi-tasking OS, so background processes have a nasty way of messing up any sort of timing on this level.  With Windows, the best accuracy you can hope for is on the order of milliseconds.
Message 7 of 10
(8,354 Views)
If anybody can convert that VI to 7.1, I can do it for 7.0.
- Partha ( CLD until Oct 2027 🙂 )
Message 8 of 10
(8,119 Views)
Marc,
I opened it in LV 8.5 eval & built it in 7.1 & ran, but it crashed LV.
I think the parameter has a data type U64, mainly meant for 64-bit processors. It is available from LV 8.0 & upwards only.
That might crash LV I think...
So, it may not be doable in LV 7.x.
Message 9 of 10
(8,114 Views)
Marc,
You can see the below thread for an earlier version in 7.1.
http://forums.ni.com/ni/board/message?board.id=170&message.id=197442&view=by_date_ascending&page=1
Message 10 of 10
(8,111 Views)
